Old 07-30-2007, 03:34 AM   #1
russb
Default Rossler Trans and Precision Perf Shifter
Carl Rossler turbo 350 with 242 first gear light weight low drag competition trans,aluminum forward drum,aluminum high gear drum,spec 2nd gear sprag system,rossler ross-lock forward and reverse valve body,high perf trans spec shift pattern,moroso deep pan,light weight low drag trans brake,also a precision Perf shifter,5 ft cable,shifter supply kit,turbo 350 trans lever and bracket,458 pro-hydro with saftey netural,air shifter has 3 positions start switch, rear cable exit,this set up is almost brand new it was run only 5 times and the trans was pulled and a 4 speed manual installed, this setup cost 5150.00 new looking to get 4250.00,
russb is offline   Reply With Quote
Old 08-07-2007, 01:19 AM   #2
russb
Default Re: Rossler Trans and Precision Perf Shifter
Still available and for a good price.
