Liked 130 Times in 20 Posts
For Sale-
Used Auto Meter 17 channel data logger. Includes software, download box, 50' download cable, dual axis accelerometer, engine rpm, input shaft rpm sensors, driveshaft rpm with collar for 9" ford rear end, oil pressure with sender, fuel pressure with sender, and 4egt used sensors and 4 older used sensors (2 of the sensors last used were not reading correctly and need to be swapped or replaced), I have the instruction manual, a box of misc extra sensors, pickups, wire extensions and connectors. $699 http://www.racingjunk.com/Gauges-Ins...ta-Logger.html SBC 327/250 pistons JE job #580450 8 pistons used and coated / 3 pistons new uncoated. 4.032 bore / .875 pin 2.500 long / .043-.043-3.0mm oil ring. Bare piston weight 412 grams $550 SBC 327/350 pistons JE job # 243938 8 pistons coated skirts measure 4.060. .043/.043/3.0mm oil ring. Bare piston weight 395 grams $400 4gc Carburetor built by Davinci, hasn't been run in a few years. $350 Call text or email for more information or pictures. Thanks Brad Z (616)437-4958 brad@zaskowskibuilders.com
Brad Zaskowski 3697 STK, SS Last edited by Brad Zaskowski; 09-30-2016 at 01:12 AM. |
