Old 09-15-2016, 04:56 PM   #1
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
Default PG internal T Brake Solenoid
The internal T Brake in my PG will not hold. Happened all of the sudden and I am thinking it is the solenoid. Called ATI and they no longer stock the valve body or parts for this unit. Has anyone got a source for this solenoid or any information about it? ATI isn't able to provide any information. I have 16 ohms of coil resistance - don't know if that is normal or FUBAR. I run a 16v system and wonder if these coils are prone to saturation?
Thanks in advance for any help you can provide
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
Old 09-15-2016, 06:17 PM   #2
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
Default Re: PG internal T Brake Solenoid
16 Ohms would be 1 amp at 16 volts, so that sounds about right for that little internal solenoid, Mike.
Old 09-15-2016, 06:47 PM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I have one somewhere in my garage. Complete valve body with internal solinoid. Trans was built by Select and I they used ATI parts back then. Worked fine as a long tail trans. Had it changed to a shorty to fit a dragster and trans brake no longer worked. Had another complete trans built. VB was given back to me and is in a box somewhere. I can look for it and check the ohm reading on the solinoid. You can energize it and should hear it click. 16 ohms does sound like what would be a good number for a small coil.
Rich Biebel
S/C 1479
Stock 147R
Old 09-15-2016, 08:36 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Mike , I have one on the bench right now for a customer .
It reads 17.8 ohms
I have to look in my parts bins ,I may still have a spare or two. ....I used to use these for my Mud racer customers.
Old 09-15-2016, 09:48 PM   #5
Mike Semeniuk
Thanks for replies so far. I was thinking 16 should be close; sound like it is. I will drop the VB tomorrow and actually power it up on bench and see if it operates and look for other possible problems . So I may be replying to some of you soon. Thanks again for your help.
Old 09-16-2016, 06:32 AM   #6
Robbie Welch
Liked 262 Times in 124 Posts
I run a Trans Brake with an internal solenoid not and ATI mine has a safety pressure switch. If ATI uses the switch check that.
