Old 07-21-2016, 12:09 AM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default IHRA ProAm Capitol Raceway
What fuel is available there?
Old 07-21-2016, 07:31 PM   #2
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Default Re: IHRA ProAm Capitol Raceway
Speed unlimited morningside md about 20 mins or so from the track. We have Sunoco and open at 10 am 301-420-2727 my ext 111
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 07-23-2016, 08:12 PM   #3
gbur
I am not aware of a rule change that allows other than pump gas for a pure stocker
Gary Burr IHRA MEMBER # 1958 Stk 1949
gbur is offline   Reply With Quote
Old 07-24-2016, 12:11 AM   #4
Duane Eiskant II
You actually have to watch using pump gas as 99% of it will NOT pass fuel check. Went thru it too many times with bobby butlers mustang. I'd worry about pure stockers with the wrong camshaft and aftermarket/upgraded brakes that are both not legal
Duane Eiskant
Old 07-24-2016, 01:07 AM   #5
Dan Fahey
Dan Fahey's Avatar
I use mostly Sunoco 93.
Like to add some 260 Gx 98 gas with no ethenol.
Pure Stocker are not checked for fuel.
Love we can use pump fuel.
Old 07-24-2016, 11:07 AM   #6
Duane Eiskant II
Pure stock, crate motor or gt at a true old school national event WAS fuel checked. Never have done it at divisionals and since that's basically all we have in Ihra anymore no one gets checked. Maybe I'll set an example next week at capital it's only $50 to protest for fuel check at any time. Would you like to take a chance on your pump gas passing? I don't mind spending $50 to prove a point…
Duane Eiskant
Old 07-24-2016, 01:20 PM   #7
Dan Fahey
Dan Fahey's Avatar
Duane Fine with me!
Not sure what IHRA would be testing for?
The rules are clear we can use pump gas.
Add a little race gas. So do not know what the alarm is.
Was fuel checked at ClassNationals 2 years ago !
What would they be looking for ?
Dan
Old 07-24-2016, 03:20 PM   #8
gbur
If this is directed at me , if those are the bones you wish to roll , so it be
Old 07-24-2016, 03:36 PM   #9
Duane Eiskant II
Gary NO. There is however some people claiming pure stock that aren't pure stock by the rule book. Example brakes: OEM upgrade allowed not aftermarket! Tim griffeth (sp?) had his pure stock mustang back in the day and switched brakes on the front which then got him tossed out of pure stock and into traditional stocker status. Back to fuel in pure stock. The approved fuel sheet says "pure stock entries may utilize OEM unleaded blends meeting rule book specifications" so we go to the rule book where stock has to remain a dielectric constant of +2.3… pump gas won't have that unless your getting it from down south as they use a different blend. (If you'd like I'll bring my fuel checking equipment). SO when mixed with whatever you want to mix it with, it really goes off the scale. Kinda like me mixing C11 and C25. Stock is a rule book based eliminator if you don't follow the rules in the book, you have a regular bracket car so you should claim the real class your in. Either footbrake or top.....
Duane Eiskant
Old 07-24-2016, 05:11 PM   #10
Dan Fahey
Dan Fahey's Avatar
Duane;
Every once in a while someone will make a mistake.
As for fuel it is open and pump gas is what it is.
Where it is available locally and Unleaded Track gas.
Until middle last year drove my car to the track.
So only thing I could use was what was at the gas station.
Never understood the need to run just expensive race gas.
Our rules are basically before the Open Spring Rule.
Our ETs reflect the times.
If we are within the spirit of the law we are good.
Seeing more Pure Stockers this year.
Which is cool.
Very fun cost effective way to run stock.
D
