Old 07-14-2016, 04:20 PM   #1
nickh
nickh's Avatar
Liked 650 Times in 194 Posts
Default Garage Sale
1. 4.11 ring & pinion for 8.5 brand new never used $100.00
2. Muncie M-21 4 speed transmission with clutch fork and bellhousing, no linkage or shifter. Serial numbers show out of 1969 midsize. Excellent condition $850.
3. Kirkey racing seat with mounting plates, was passenger seat out of my racecar, no belts but does have upholstery. Excellent condition $175
4. New in package Milodon copper head gasket set for sbc. $75
5 Comp Cams Roller Cam brand new in box part #12-822-14 , Jegs sells this for $386.00 will sell for $275.
6. LS-1 Camaro custom built mandrel bent 3" y-pipe with magnaflo mini cats, brackets, 02 sensor bung is already installed. New never installed $250.
7. 3 sets of Comp cams racing springs good up to 800 inch lift used, very few runs $50 per set.
8. 2 sets of comp cams roller lifters, used but in excellent shape $50 per set.
9. 830 Holley DP on car can hear run, runs great but can use a rebuild $250
10. Davinci built 950 Holley, built for high compression sbc, brand new never mounted still in bag. Reason selling going Dominator. $750
11. Driveshaft setup for G-body BBC & Ford 9" 1350 yokes $200
12. Comp Cams 3 pc billet timing cover sbc brand new in box comes with all hardware, gasket, etc.. $225.00
13. Dynatech new in box sbc ceramic coated step headers for chevelle, Nova, camaro 1 5/8 to 1 7/8 never installed $275.00
14. Dynatech Ceramic Merge with cone Collectors (pair) 780-01515C 1 7/8 x 3 $275.00
Will be adding more stuff as I continue to trip over it.
15. 358 sbc bracket motor, 13.5 compression, roller, comp cams, Manley HD Rods, SRP pistons, Dart 215 heads with extensive port work and matching dart intake, motor has been 9.70's at 2750 lbs. door car, most passes were held to 10 flat. built by G&G in Houston Texas. Motor has very few passes but can use a freshen up due to not being raced in a while, have kept it turned over and cranked up several times a month. Mini starter, comes carb to pan water pump to flywheel, still in car and crank car and take video. $3500 as it sits or will include all sbc spare parts that I have for $5200. (Includes headers & carbs listed above plus much more. Motor runs on VP 112 or 114. Motor has a total of 25 passes on it. Building bbc now.
Photos available upon request
832-727-0326 I need room in the garage no calls after 9 pm cst. Can ship buyer pays freight, or can deliver in Houston, Beaumont area. No trades. I can do Paypal
Old 07-15-2016, 01:49 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Garage Sale
PM for headers -
Rich Taylor
I/SA - 321
