Old 07-11-2016, 11:12 AM   #1
BA1927
BA1927's Avatar
Liked 26 Times in 10 Posts
Default Mopar STUFF
WELD RACING ALUMASTAR 2.0 - 15x3.5 5 on 4.5 BOLT CIRCLE WITH BRAND NEW MOROSO 17600 760-15 FRONT RUNNERS - WILL SELL or SWAP RIM'S ONLY FOR ALUMASTAR WITH 1 3/4" - 2" BACK SPACE OR SELL THE WHOLE PACKAGE WILL BE AT NEW England DRAGWAY FOR THE LODRS EVENT JULY 22 OR FEEL FREE TO CALL 508-TWO SIX NINE-9611 OR E-MAIL ba1927@aol.com LET'S TALK WHEEL'S ONLY $600
MOPAR 8 1/4" COMPLETE REAR WITH (2) SET'S OF GEARS - MEASUREMENTS: BACKING PLATE to BACKING PLATE-54 3/4" - INSIDE PERCH to INSIDE PERCH 41" - OUTSIDE PERCH to OUTSIDE PERCH 46" - CENTER PIN to CENTER PIN 43" ---- IN THE TRUCK WHEN SHIPPED FROM WEST COAST - has 4:88 GEAR IN RIGHT NOW ALSO HAVE A TAKE OUT SET OF 4:56'S
TWO (2) SET'S OF M/T 9x30x15 RADIAL STOCKER SLICKS -$200 PER SET
ONE (1) SET M/T 29.5X9X15 BIAS SLICKS WITH TUBES FRESH LAST YEAR
$300
(1) MOPAR 1993 DODGE DAKOTA ECU # P5249516 ( 92-93 STICK or AUTO) MODIFIED AT MOPAR 5.2 MAGNUM MOTOR RAN 12.46 et W/THIS ECU --- $250 obro
(1) DODGE/PLYMOUTH 318-360 MAGNUM AC DELETE ALTERNATOR BRACKET WITH ALL HARDWARE
(1) MOROSO S B CHRYSLER ALTERNATOR MOUNT NEW (MINUS TURNBUCKLE) WORKS WITH NIPP 93mm-115mm --- $100
(2) STAINLESS WORKS MERGE COLLECTORS 1 5/8" PRIMARY TUBE X 3" COLLECTORS $300
CALL 508-824-2238 LEAVE A MESSAGE
(1) NEW MOROSO 89552 0-15 LB 4" TIRE PRESSURE GAUGE NIB - $120 OBO
(1) MSD # 8211 FIREWALL FEED THRU NEW - $12
(1) MSD NEW IN THE BOX NEVER USED MSD PRO POWER COIL #8201 - $100
CALL 508-824-2238 LEAVE A MESSAGE IF I DON'T ANSWER
BA1927 is offline   Reply With Quote
