Old 06-22-2016, 05:27 PM   #1
mykids
Liked 2 Times in 1 Post
Default Roadster sold cleaning out the garage
BB CHEVY WITH ALL THE GOOD STUFF JESSEL - MSD - DART BY AL NEIL WITH PORT MATCHED INT - CHUCK NUYTTEN DOMINATOR - IRON MERLIN HEADS WITH MATCHING INT - SUPER DAMPER - WILL FRESHEN AND CAN BE PURCHASED WITH EITHER SET OF HEADS OR BOTH - LET'S TALK MOTOR RAN 10.89@137 MPH AT 2825 LBS WITH 3 SECONDS OF STOP AT SUPER GAS WEIGHT IT RAN 8.73@153MPH WITH 2 SECONDS OF STOP
(3) NEW BORLA SS COLLECTOR MUFFLER (40728) 2 1/4" PRIMARY TUBE $275 ea orW/Deal for 2 ----
(1) POLISHED PG TRANS SHIELD OUT OF SFI DATE $50 ----
(1) SET BBC 4 BOLT MAIN CAP'S AND BOLT'S $100 ----
(1) 8 1/4" MOPAR REAR 4:56 GEAR SET GEARS AND INSTAL. KIT $250 --
(1) MOPAR 1993 DODGE DAKOTA ECU # P5249516 ( 92-93 STICK or AUTO) MODIFIED AT MOPAR 5.2 MAGNUM MOTOR RAN 12.46 et W/THIS ECU --- $250 obro
CHEVY BLOCK'S:
1) 283 APART FOR INSPECTION
1) 283 COMPLETE MOTOR STILL TOGETHER
(1) NIB PRECISION GEAR 4:10 RING/PINION FOR GM 7.5 (MONTE CARLO CUTLASS etc)
$125
(1) MALLORY DUAL POINT TACH DRIVE DISTRIBUTOR #2664501 (USED) $250
(1) MALLORY UNI LITE CHEVROLET DISTRIBUTOR (USED) $250
(1) TCI 6" ALL ALUMINUM BB CHEVY BALANCER $100 (RED ANODISED)
(6) FRAM HP4 FILTERS - $60
(2) BBC STEEL BILLET ROLLER CAMS
16) BIG BLOCK CHEVROLET ROLLER LIFTER's W/LINK BAR's $250
(1) JONES MECHANICAL TACH & CABLE -- $150
(1) MOROSO MECHANICAL TACH - MOUNTING BRACKET - CABLE --- $250
(4-5) ASSORTED FORD TOP LOADSER CLUTCH DISC AND PRESSURE PLATE'S
(1) NEW MOROSO 89552 0-15 LB 4" TIRE PRESSURE GAUGE NIB - $120 OBO
(1) MOROSO/COMPETITION ENGINEERING (NEW) C4010 MUSTANG LATERAL ENGINE LIMITER - $54
(1) USED SET OF SBC HOOKER RACE HEADERS HPC COATED 1 3/4" PRIMARY TUBE FOR NOVE 68-72 or CAMARO 67 -69 - $250 OBRO
(2) STAINLESS WORKS MERGE COLLECTORS 1 5/8" PRIMARY TUBE X 3" COLLECTORS $300
(1) NEW NEVER USED PINGEL RETRACTABLE TOW STRAP --- $115
(1) RONCO CHEVROLET MAGNETO W/TACH DRIVE - $900
(1) OLDER ACD BOX (BLACK)
(1) ACD #7500 CO2 BOTTLE NEW AND NEVER USED - $60
(1) MSD # 8738 TWO STEP (2STEP) -- $55
(1) MSD # 8211 FIREWALL FEED THRU NEW - $12
(1) MSD NEW IN THE BOX NEVER USED MSD PRO POWER COIL #8201 - $100
(1) DEDENBEAR TSC-4 THROTTLE STOP CONTROLLER
(1) HOLLEY LIST # 3310-5 --- 750 CFM, MANUAL CHOKE
DUAL FEED FUEL BOWLS, SQUARE BORE --- $150
1) HOLLEY LIST # 4412-2 -- 500 CFM TWO BARRELL MANUAL CHOKE --- $150
(1) CHEVROLET BB RECTANGULAR PORT INTAKE # 6269378 JUST SQUARED -- $125
(1) NIB 1962-1965 CHEVY NOVA REAR WINDSHIELD GASKET
(2) (TAKE OFF)M/T RADIAL STOCKER SLICK'S --- both set 30x9x15
(2) (TAKE OFF) GOODYEAR RADIAL STOCKER SLICK'S
(2) M/T 29.5x9.0x15 (3056) WITH TUBES ONE SEASON OLD AND NOT USED WEEKLY - $300 GOOD FOR STICK SHIFT
mykids is offline   Reply With Quote
