Old 06-18-2016, 09:42 AM   #1
12BOLT
Liked 2 Times in 2 Posts
Default 302 275 Ford crate motor
302/275 Ford Crate Motor clone
Eagle crank 3.015 stroke, Eagle H beam rods, speed pro pistons .060 over, Stock Ford block poured bored .060, Comp cams .498 lift cam ground for this app, Comp roller rockers, Ford hyd. roller lifters, Ford Y aluminum heads, Wieand aluminum intake, Holley 650 carb, wieand aluminum water pump with moroso electric drive, MSD distributor, SFI balancer, TCI SFI 157 tooth flywheel, Milidon oil pan selling Carb to pan 4,000.00 has been low 7's in the 1/8 mile.
C4 trans red clutches, Art Carr reverse valve body, Coan servo, less than 10 1/8 mile passes 1000.00
PTC 8 inch 4500 stall converter just freshened 4 passes 500.00
PM or contact me 12bolt2712@centurylink.net
12BOLT is offline   Reply With Quote
