Old 06-16-2016, 12:53 AM   #1
kansas stocker
Liked 249 Times in 48 Posts
Default aluminum torque plate, cast iron heads
I need to make a torque plate and aluminum is very easy to come up with. Is this a waste of time? Would steel be better? Is there a good way to come up with cast iron? This is a low budget project.
Thanks for the help.
Pete
Will be using studs if this makes any difference.
kansas stocker is offline   Reply With Quote
Old 06-16-2016, 07:27 AM   #2
carl hinkson
Liked 18 Times in 10 Posts
Default Re: aluminum torque plate, cast iron heads
Pete
I have both and so far seen no difference between the 2, as far as studs VS bolt there is a difference in distortion.
On OEM blocks even switching to gaskets with a different bore diameter makes a difference at the top of the cylinder . Stock blocks are pretty frail.
carl hinkson is offline   Reply With Quote
