Old 06-12-2016, 05:05 PM   #1
jscamaro1
Liked 3 Times in 1 Post
Default 88 Camaro stick shift stock suspension
For Sale: 1988 Camaro Stick Shift Stock Suspension Drag Race/ Street Car
Engine: Very reliable low maintenance
406 ci
Afr heads
Scat crank, Eagle Rod, Manley piston
Jesel valvetrain, comp street solid roller
750 carb
Be Cool Radiator
Drivetrain: Stock style
G Force clutch assisted four speed (30 runs on new 3rd gear set and 4th gear slider)
Long vertical Gate
Advanced clutch dual 7" clutch
9" housing 5.13 Pro Gear with spool
Mark Williams center section, axles & Driveshaft
Racepak sportsman data logger with added clutch sensor input
Chromoly single wheelie bar, Chromoly anti roll bar
Spohn offset Moly lower control arms, custom torque arm
Afco Da rear shocks, Koni Sa front struts
Adjustable Rear Coil spring
Wheels,tires and brakes:
Alumastar all around Hoosier tire 30X9 billet front lugnuts
Willwood fronts and strange pro rears
Body and paint:
This a beautiful black thirdgen, it has won multiple awards
Best of class @ Super chevy show three years in a row
Editiors choice top ten cars at the show
The car still has ALL working street functions and could driven to local cruise nights etc. Also still have a bolt on exhaust system that can go with car. Stock hood is available.
It has a 8 point moly rollbar with an added x brace
Extra Notes: You will not be disappointed with the car it is a very nice car and not just thrown together.
There are six passes on a freshened engine, clutch and slicks
Car has been 10.00 @ 133.59
Please call with any questions about the car. We have always done all the work, made parts and pieces for the car so anything can be answered. I have owned the car for 16 years.
Title in hand $26,500
Thanks Justin Stout 309-314-8211
jscamaro1 is offline   Reply With Quote
