Old 05-29-2016, 08:01 PM   #1
MYLINRACING
MYLINRACING's Avatar
Default TH 350 help
I run a turbo action 350 with a ATI converter, recently the converter would not flash above 4,000 and it a 5,800 stall converter. So we put the spare converter in which is a 5200 and we have the same issue won't go above 4,000. I find it hard to believe i have two bad converters. Any ideas what the problem could be?
Thanks.
Andy Mylin
Andy Mylin
1987 Pontiac trans am
2441 I/SA
MYLINRACING is offline   Reply With Quote
Old 05-29-2016, 09:30 PM   #2
jmantle
Liked 172 Times in 81 Posts
Default Re: TH 350 help
Thanks.
Andy Mylin
Put a pair of water pump plyers on the stator support and make sure it won't turn.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 05-29-2016, 09:34 PM   #3
Liked 1,878 Times in 422 Posts
Stator shaft (big splined tube) is possibly loose. Also you could have another pump problem, or valve body problem. Do you run a transmission cooler?
Old 05-29-2016, 09:37 PM   #4
MYLINRACING
No Sir, I don't run a cooler
Andy Mylin
2441 I/SA
Old 05-29-2016, 10:18 PM   #5
I'm not a sir. Just a guy.
Any other changes before this started?
Checked the basics?
Fluid level?
Ignition sytem?
Fuel system?
Timing?
Old 05-30-2016, 12:55 PM   #6
MYLINRACING
We have changed just about everything MSD box, coil, fuel pump, fuel reg, Carb, Converter. Trans fluid level looks good and the timing is were it should be. Checked the stator shaft but it is tight. Going to call Turbo Action in the morning and see about a new valve body.
Andy Mylin
2441 I/SA
Old 05-30-2016, 01:06 PM   #7
Do not just replace parts arbitrarily. It has not worked so far, and is not likely to work, at least until you have spent way too much money.
The next thing to do is to perform the appropriate pressure tests on the transmission.
It is the pump that charges the converter with fluid. The valvebody controls line pressure, and as a function of line pressure, there is charge pressure to fill the torque converter with fluid. It is possible that there is one or more problem inside the pump.
Old 05-30-2016, 03:26 PM   #8
HIGHOCTAIN2000
if your engine is down on power you will lose stall speed
HIGHOCTAIN2000 is offline   Reply With Quote
Old 06-01-2016, 08:31 AM   #9
MYLINRACING
Engine checks out fine no issues there.
Andy Mylin
2441 I/SA
Old 06-10-2016, 07:31 AM   #10
Lou Jeffery
Did you ever figure out what the issue was? Is it running fine now?
Lou Jeffery is offline   Reply With Quote
