Old 05-23-2016, 10:47 PM   #1
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Default 327 Super Stock engine and Jerico transmission
For Sale:
Jerico 4 speed DR4 top and bottom loader transmission-
Long pistol grip shiftier with stops and line loc button.
Chrysler 1 3/16 18 spline input for GM stock depth bell housing
25 runs since taking apart, checking everything and replacing what was needed.
3.19 / 2.00 / 1.39 / 1:1
Trans was run in our H stocker the last year.
$2,800
Parsons and Myers built 327 Super Stock engine.
Can be run with 4gc carburetor as 1965 250hp engine, with a Holley as a 67 300 hp engine or with the Quadrajet carb as 1966 275 hp engine.
Quick Fuel 585 carburetor
HVH super sucker 2" carb spacer
Edelbrock intake by Heads Up
Heads up heads (1 new head this past winter)
Jesel shaft rockers
Manley Valves
Sheet metal valve covers
7/16 tapered push rods
PAC valve springs
Bowtie block
.937 Jesel keyway lifters
50mm Roller cam bearings
Comp Cams camshaft
Jesel belt drive
Diamond pistons
Total seal piston rings
Manley rods Honda journal
Bullet cams built lightweight crankshaft
Mallory front drive distributor
ATI Balancer
Aluminum kick out oil pan
This engine is built with the best parts, is very reliable and went -.91 under (9.589 @ 136.98 in GT/E) in Charlotte at the points meet rd1 50 lbs heavy with regular oil.
$15,900
Engine and trans will be at the sports nats in Bowling Green this weekend.
Call text or email for more information.
Thanks
Brad
(616)437-4958
brad@zaskowskibuilders.com
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
Old 05-27-2016, 11:12 PM   #2
nhra63corv
Liked 3 Times in 2 Posts
Default Re: 327 Super Stock engine and Jerico transmission
Hello Brad , I'm still Looking for another engine , I've found a 305 engine trying to work a deal on it , are you firm on your price ? Can you tell me the bore of your block and how many runs on the crank and rods ? Thanks Jeff
nhra63corv is offline   Reply With Quote
