Liked 10 Times in 7 Posts
Will be cleaning out garage soon! Cars are sold so parts will go! Here's partial list:
2 bare 455 Buick blocks .010/.020 buick crank .030 over TRW flat top pistons (used) #H292NP Lunati stage1 cam (used) 1971 stocker heads w/TA SS valves Poston springs $500 1971 Clean bare heads $200 Venolia stocker pistons (used) 4.375 Q-JET #7043242 modified air bleeds idle circuit $200 Q-JET #7041540 $50 .030 LT-1 coated Venolia's w/dykes ring set (new) Eagle rods SCR-5700 BB King accular bearings w/ARP bolts Gm crank .010/.010 Roll Master double roller timing chain Heads UP! prepped LT-1 heads never used #10128374 Unassenbled $3000.00 Heads #10207640 New never used stock valves and springs $400.00 .060 350 LT-1 w/94-275 Venolia's stock rods .010/.010 GM Crank Lunati stocker cam Would make good street or bracket short block $1000.00 OBO ATI flex plate 153t used $40 TCI flexplate new in box #399773 168T $75 ? New flexplate #3450231 153t $40 5.14 ring/pinion for 12 bolt $50 used MSD HVC-2 coil for 7 series ignition $50 Speed Pro rings: #R-9278 5 New $75 #R-10246 5 New $75 Crane springs #99846-16 $100 Misc gauges (Autometer) Tach, water, oil Rimac bench spring tester $350 Mitutoyo #511 bore gauge $150 leak down tester lots of other stuff I won'r be needing SLP Ram Air hood for 98' up firebird (slight damage to corners but easy repair) never installed in primer.$450.00 Will try and take inventory and post prices after this weekend Contact Chuck Garey Rgarey@chapusa.com Last edited by Chuck Garey; 07-23-2007 at 10:27 AM. Reason: update info and pricing |
Ttt
Heads cannot be verified as heads up. Sorry
Liked 269 Times in 99 Posts
Sent you 2 e-mails
Am interested in the spring tester and some other tools you may have.
