Old 05-15-2016, 03:03 PM   #1
KG-CMF
Default Coan 7 in converters, dam metering blocks, misc parts
COAN 7 INCH CONVERTER TX3017D - 8800 STALL- LOW RUNS- $600
COAN 7 INCH CONVERTER TXB2817D - 9000 STALL- LOW RUNS- $750
BOTH TURBO SPLINE, USED WITH 324 CU.IN. ENGINE AND KILGORE 400 TRANS 233/148
1 pr- DAM BEST Metering Block, Ultimate Pro Stock- $300
8 NEW- PSI DR1250 TRIPLE VALVE SPRING, 5 REG, 3 MAX LIFE- $120
1- EASTCOAST AUTO ELEC. STARTER SBC MINI TYPE- $100
1- CSR STARTER DRIVER-SIDE MOUNT #100PDS- $150
1- MR GASKET 104, GM SPLAYED VALVE INTAKE GASKET- $10
1- FEL-PRO 1641, GM SPLAYED VALVE VALVE COVER GASKET, 5/16 THK. STEEL CORE-$20
315-542-1195 / kgotie@twcny.rr.com
Kevin Gotie
KG-CMF is offline   Reply With Quote
