Old 04-25-2016, 05:31 PM   #1
projack1
Default 388 Small Block Chevy Motor Complete from Carb to Pan
388 Small Block Chevy Motor Complete from Carb to Pan. $13,900.00 OBO Call Frank Cervelli 925-584-7934 or Kim 305-798-9698
Brand New BowTie Block
Motor just went through a freshen up and run on a DTS dyno. Made 834 hp and 567 ft. lbs. torque.
3 5/8 stroke Crower Crank
GRP Aluminum Rods
CP Pistons
MSD distributor and crank trigger.
MBE GB 2300 Heads
MBE Cast Dominator Manifold
Electric Water Pump
Dominator Carb Included.
T&D Rockers
Manton Push Rods
New PAC Springs
Moroso Vacuum Pump
Comp Cams Belt Drive
Greg Slack Converter
Performance Welding Stainless Headers
Can get you a copy of the Dyno Sheet and photos.
projack1 is offline   Reply With Quote
