Old 04-18-2016, 01:08 AM   #1
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Default 327 Super Stock engine for sale
For Sale:
Parsons and Myers built 327 Super Stock engine.
Can be run with 4gc carburetor as 1965 250hp engine, with a Holley as a 67 300 hp engine or with the Quadrajet carb as 1966 275 hp engine.
Quick Fuel 585 carburetor
Edelbrock intake by Heads Up
Heads up heads (1 new head this past winter)
Jesel shaft rockers
Manley Valves
Sheet metal valve covers
7/16 tapered push rods
PAC valve springs
Bowtie block
.937 Jesel keyway lifters
50mm Roller cam bearings
Comp Cams camshaft
Jesel belt drive
Diamond pistons
Total seal piston rings
Manley rods Honda journal
Bullet cams built lightweight crankshaft
Mallory front drive distributor
ATI Balancer
Aluminum kick out oil pan
This engine is built with the best parts, is very reliable and went -.91 under (9.589 @ 136.98 in GT/E) in Charlotte at the points meet rd1 50 lbs heavy with regular oil.
$15,900
Engine will be in my car at Charlotte nats, Indy pts, Atlanta nats, and Sport nats in BG coming up.
Call text or email for more information.
Thanks
Brad
(616)437-4958
brad@zaskowskibuilders.com
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
