Old 04-17-2016, 08:11 PM   #1
SS427
Default 1969 Super Stock Camaro
1969 427 Camaro for sale. It runs SS/AA, SS/BA, or SS/CA. The motor is a freshly rebuilt .070 over 427 with all legal parts. 077 cylinder heads, Eagle rods, JE pistons, and GM 6223 steel crank. New custom ground mechanical roller Comp Cam and lifters. Holley 850. Jesel belt. Moroso super stock pan. Ceramic coated step headers. Cheetah air shifter. MSD 7AL-3. MSD crank trigger, wires, and crab cap. Aluminum drive shaft. Turbo 400 with all aluminum internals and JW bell housing. ATI converter. Strange adjustable rear coil over shocks. Dana 60 rear with pro gear. Ladder bar rearend. Wilwood brakes on all four corners. MagnaFuel pump. Alumastar wheels with Hoosier radial slicks on the rear. Optima battery. Cage certified to 8.50 this month. Car has not been down the track since rebuild. 30,000. Serious inquiries only please. Car is located in central Ohio. See Racingjunk Ad #182681109 for the picture. Please call or text 614-940-6398
SS427 is offline   Reply With Quote
