Old 04-03-2016, 01:30 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Pan vacuum question
I'm using manifold vacuum for pan vacuum and my fresh engine is a little down on pan vacuum compared to last year's engine. Last year the pan vacuum would creep up to a little over 6" and this year I'm at about 4. Seals are not in backwards. Before I put the engine in the car I put a vacuum pump on it and I could hear it leaking at both crank seals. I used a Felpro viton single lip rear main, 2918 I think. It's the same seal I used in the last build. Is there any chance the seal improves with some run time, like it burnishes or smooths on the very edge?
Ron Gusack is offline   Reply With Quote
