Liked 101 Times in 27 Posts
For clarification this may help......the fuel pressure always holds steady once the engine is started until it is shut down.......it never restarts at the same pressure but it holds at whatever it starts at, there is no fluctuation while running. Set at 6 while running and holds forever until shut down that is great.... BUT it will restart with more or less fuel pressure and hold until readjusted or shutdown. Checked the voltage, the vent, the fuel is dumping on foam and the fuel cell is kept full. Open to any and all help. I am running a filter before the fuel cell and another a couple of feet from the carburetor. The Aeromotive gauge at the carb always agrees with the Autometer on the cowl. Thanks for any comments. Interesting note......Aeromotive told me I didn't have a problem-----really ???
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Liked 275 Times in 76 Posts
Rusty,
I reread your other post so I hope I did not miss something there. Explain your layout and where the pump,regulator and cell are along with fittings and line sizing. The reference port on the regulator diaphragm is open to atmosphere right? If this is plugged or blocked that could play a role as the regulator warms and cools it will change your setting. Sean
Sean Marconette 84 Mustang 5060 SS/N Last edited by Sean Marconette; 03-31-2016 at 10:15 AM. Reason: More info |
Liked 320 Times in 102 Posts
The fuel return should not be dumping on the foam...
The return should be submerged so the returning fuel does not cause foaming..
Liked 752 Times in 138 Posts
Could be an instrument hysteresis or "stiction" issue and nothing more.
