Old 03-12-2016, 09:01 AM   #1
SPECK1148
Default Holley Dominator EFI System with Throttle Body
Ecm, wiring harness (sensors that come with it are fuel and oil pressure drives driveshaft, air and map, 2 O2 sensors) Magnafuel regulator and bracket, accufab 2.56 bore throttle body with tps sensor, big duke intake with fuel rail and 85 lbs injectors and fuel line to the regulator.
Here is the racingjunk Ad #182660458 with pictures.
Contact only if interest 315-529-1593
SPECK1148 is offline   Reply With Quote
