Old 02-25-2016, 11:48 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1965-1970 396 427 Blocks, Heads Parts
1965 3856208 square port heads stock both dated B-25-5 $2500
1968 3919840 square port heads stock freshly rebuilt dated D-23-8 & E-20-8 $1750
1968 427 4 bolt casting #3916321 dated H-19-7 and stamped CE850867 warranty exchange engine with the 3919840 square port heads dated A-10-8 & A-11-8 along with the 11 to 1 TRW pistons with 3/8 dimple rods and 6223 steel crankshaft $5000
1968 396 & 427 aluminum intake #3933163 dated 3-6-68 $450
1969-70 402 4 bolt warranty exchange block dated H-21-9 casting 3969854 and stamped CE066893 $2500
1969 3919840 square port heads both dated A-21-9 and stock $1250
1969 427 Copo engine casting #3963512 and stamped T0513MN with no visible vin or date code. Block is all machined and set for .030 with new 11 to 1 pistons with 3/8 dimple rods, 6223 crankshaft, 3919840 heads dated A-29-9 & C-25-9, oil pan and 3933163 aluminum intake dated 4-30-69 $10,000.
1969 3946074 aluminum heads with early date codes of 12-17-68 & 12-19-68 with one not having the casting number stamped on it very rare early set of L88 or ZL1 aluminum heads $3500.
1969 4296 Holley carb dated 983 used on 427 ZL1 & L88 applications only $2000.
1969 3933198 aluminum ZL1 & L88 intake dated 12 ? 68 $750
Can ship these parts if you cannot pick up and can provide pictures with a email address. Can be reached at 330-770-2517 for any questions.
dlv4540 is offline   Reply With Quote
