Old 01-27-2016, 11:28 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969-70 402 L78 & L89 Warranty Exchange Block
This is a standard bore 402 4 bolt block casting number 3969854 dated H-21-9 with a CE066983 stamped on the deck and a assembly date of T 08 9 on the backside corner. This block could have been used in a 1969 Camaro due to the fact those were built into the second week of November of 1969 or in a 1970 Chevelle or Nova application. This block can be used as the L78 375HP iron head or L89 375HP aluminum headed application. The block was cleaned, magged and pressure tested with two fitted sleeves and is ready to build $2000. Hard to find a warranty block and perfect for the applications stated and great for a restoration or super stock class set up. Can ship if you cannot pick up and can provide pictures with a email address. Any questions I can be reached at 330-770-2517.
dlv4540 is offline   Reply With Quote
