Old 01-26-2016, 01:35 AM   #1
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Default M/T rear wheels and tires-9" rear end housing-Mcleod Clutch
For Sale:
McLeod Soft Lok clutch SOLD
Mickey Thompson drag wheels 15x14 with 4" back space, dual bolt pattern with 5 on 4.75 & 4.5 with M/T 3068 tire 31.0x10.5-15 tires. Wheels are a nice set that were used as a spare set for my car and mostly rode in the trailer. The tires are about three years old but probably only have 30-35 runs on them. They were last run last spring. $800
9" Ford rear end housing from my Super Stock car. Housing was originally built in the late 1980's and has been in my car since. The housing is narrowed and measures 46 5/8" axle flange to axle flange. It has been braced, has 4 link brackets (25 7/8" center to center), shock mount brackets (20 1/2" center to center), has wheelie bar and anti roll bar tabs also installed. The Axles are Mark Williams 35 Spline axles that were new around 2008 and include 5/8 wheel studs, spacers and nuts. Axles show no signs of twisting on the splines. I also have a spare original axle that goes with the setup. The housing itself is in ok condition, it has some spots that have been patched up around the shock mounts which you can see in the pictures, but everything is in good working condition on it. $1,000
Call text or email for more information and pictures.
I will be heading to Dayton, OH and Louisville, KY this coming weekend 1/29-1/31 and could do partial delivery on any of these items.
Thanks
Brad
brad@zaskowskibuilders.com
(616)437-4958
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
