Old 01-23-2016, 10:39 AM   #1
mykids
Liked 2 Times in 1 Post
Default Need Room In The Garage Good Parts Not Being Used
(1) USED WELD PRO-STAR 15x14 (6.5 B.S. 5x4 3/4" B.C. GM - CHEVY) $150 OR I WILL BUY YOUR WHEEL
(30) NEW AUTOLITE AG403 RACING PLUGS
(3) NEW BORLA SS COLLECTOR MUFFLER (40728) 2 1/4" PRIMARY TUBE $275 ea orW/Deal for 2 ----
(1) POLISHED PG TRANS SHIELD OUT OF SFI DATE $50 ----
(1) SET BBC 4 BOLT MAIN CAP'S AND BOLT'S $100 ----
(1) 8 1/4" MOPAR REAR 4:56 GEAR SET GEARS AND INSTAL. KIT $250 --
(1) 1993 DODGE DAKOTA ECU MODIFIED AT MOPAR 5.2 MAGNUM MOTOR RAN 12.46 et W/THIS ECU --- $250
CHEVY BLOCK'S:
1) 283 APART FOR INSPECTION
1) 283 COMPLETE MOTOR STILL TOGETHER
(1) NIB PRECISION GEAR 4:10 RING/PINION FOR GM 7.5 (MONTE CARLO CUTLASS etc)
$125
(1) MALLORY DUAL POINT TACH DRIVE DISTRIBUTOR #2664501 (USED) $250
(1) MALLORY UNI LITE CHEVROLET DISTRIBUTOR (USED) $250
(1) TCI 6" ALL ALUMINUM BB CHEVY BALANCER $100 (RED ANODISED)
16) BIG BLOCK CHEVROLET ROLLER LIFTER's W/LINK BAR's $250
(1) JONES MECHANICAL TACH & CABLE -- $150
(1) MOROSO MECHANICAL TACH - MOUNTING BRACKET - CABLE --- $250
(4-5) ASSORTED FORD TOP LOADSER CLUTCH DISC AND PRESSURE PLATE'S
(1)MOROSO 89552 0-15 LB 4" TIRE PRESSURE GAUGE NIB - $120 OBO
(1)MOROSO/COMPETITION ENGINEERING (NEW) C4010 MUSTANG LATERAL ENGINE LIMITER - $54
(1) RONCO CHEVROLET MAGNETO W/TACH DRIVE - $900
(1) OLDER ACD BOX (BLACK)
(1) ACD #7500 CO2 BOTTLE NEW AND NEVER USED - $60
(1) MSD # 8738 TWO STEP (2STEP) -- $55
(1) NEW IN THE BOX NEVER USED MSDPRO POWER COIL #8201 - $100
(1) DEDENBEAR TSC-4 THROTTLE STOP CONTROLLER
(1) DEDENBEAR DOMINATOR TS-5 (UNDER THE CARB) 4 BLADE THROTTLE STOP - (PRIMARY & SECONDARY) $300
(1) HOLLEY LIST # 3310-5 --- 750 CFM, MANUAL CHOKE
DUAL FEED FUEL BOWLS, SQUARE BORE --- $150
1) HOLLEY LIST # 4412-2 -- 500 CFM TWO BARRELL MANUAL CHOKE --- $150
(1) NEW NEVER USED PINGEL RETRACTABLE TOW STRAP --- $115
(1) 1 NEW IN THE BOX SUNCOAST PERFORMANCE 1927 FORD ROADSTER WINDSHIELD KIT COMPLETE --- $150
(1) CHEVROLET BB RECTANGULAR PORT INTAKE # 6269378 JUST SQUARED -- $125
(1) NIB 1962-1965 CHEVY NOVA REAR WINDSHIELD GASKET
(2) NIB 1962-1965 CHEVY NOVA CHROME DOOR MIRRORS W/MOUNTING HARDWARE
(2) (TAKE OFF)M/T RADIAL STOCKER SLICK'S --- both set 30x9x15
(2) (TAKE OFF) GOODYEAR RADIAL STOCKER SLICK'S
(2) M/T 29.5x9.0x15 (3056) WITH TUBES ONE SEASON OLD AND NOT USED WEEKLY - $300
CALL 508-TWO SIX NINE-9611 MORE TO COME
DRAG RACE - STREET RACE - HI PERFORMANCE - MOPAR - FORD - HOT ROD - PRO/STREET - PRO STREET - SUPER GAS - NHRA - IHRA- HOLLEY-STOCK CAR - MOROSO - MUSTANG
mykids is offline   Reply With Quote
