Old 01-17-2016, 11:55 PM   #1
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Mounting Kirkey Seats to a Cross Bar
I'm converting my poly seats to Kirkey aluminum ones - the Pro Street version - and have a question on mounting the back brace that came with the kit. It's basically a formed sheet of T-6 aluminum that bolts to the back of the seat and lays over the cross bar with no included means of attaching the two. The easiest mount I can think of would be to drill through it and use a pair of exhaust clamps to bolt it to the cage cross bar. I also have a spare weight box clamp that is drilled for a 1/2 inch bolt. I could order another and use the two of them to secure it to the brace.
Are clamps legal as a means of attachment to the cross bar or is welding required. I can't find it specified in the 2016 book. Just "securely attached"
This kind of clamp: http://www.summitracing.com/parts/pte-h7173/overview/
Thanks in advance.
Dale
Dale Shearon
68 Mustang 6394
Old 01-18-2016, 09:23 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Default Re: Mounting Kirkey Seats to a Cross Bar
I don't have Kirkey seats but my seat is bolted through the back of the seat directly through the crossbar with a 1/2 inch G 8 bolt. I just drilled a hole through the roll bar tubing. I also use this as the mounting point for the shoulder harness
Mike Pearson 2485 SS
Old 01-18-2016, 11:07 AM   #3
Jim Kaekel
Liked 535 Times in 110 Posts
FireSale: There are neat looking clamps from Allstar Performance that attach direct to the roll bar that come tapped with 1/4" threads. I attached two clamps to the cross bar and then used 1/4" bolts from the Kirkey upper mount to each clamp. Allstar part no. 10459 attaches directly to 1-3/4" tubing. There are other sizes available as well. Works and looks great.
Jim Kaekel 3836 STK
Old 01-18-2016, 02:09 PM   #4
FireSale
FireSale's Avatar
Thanks. I have a set of those that attach my relay panel to the cage support bar behind the passenger seat. It's 1 5/8 tubing so I had to make "rod bearings" out of scrap aluminum to make it fit OK. I can do that again if I can't find Allstar parts for 1 5/8 tubing.
That will fit the bill just fine.
Dale
Dale Shearon
68 Mustang 6394
Old 01-18-2016, 04:05 PM   #5
Jim Kaekel
The Allstar part no. for 1-5/8" is 10460.
Jim Kaekel 3836 STK
Old 01-18-2016, 05:13 PM   #6
FireSale
FireSale's Avatar
Jim: Order confirmation received at 12:22 today from Jegs. The ballast brackets were cheaper but these have a lower profile.
Thanks for the help. They were right in the car holding my electrical panel, but I never thought of them.
Dale
Dale Shearon
68 Mustang 6394
