Old 01-17-2016, 03:26 PM   #1
Mark Faul
Liked 43 Times in 9 Posts
Default Lots of misc parts for sale
Cleaning the shop. Some new, some used. Prices don't include shipping.
Used parts...
SBC connecting rods 5.700 long, large journal, .875 wrist pin, ARP bolts. Some people suggested they are Summit rods, others thought Oliver. $300. If not satisfied with these, I will warranty and refund your money.
1/2" wheel spacers universal 5 lug $20
2 TCI aluminum forward drums. Have slight wear. Can send pics $200 each
2 TCI aluminum direct drums. Slight wear. Can send pics also $200 each
3 steel billet splayed main caps for bowtie SBC #2,3,4 $50
Pair of coil springs 110# 14" long 2.75" ID 3.5" OD $20
Shogun "cool tool" that bolts to the converter to cool it off. $10
PermaCool electric fan 10" diameter. Was on a trans cooler. $20
Areomotive A1000 pump rebuildable, $100 (was told $200 to rebuild)
Mr Gasket 2" open carb spacer #6007, used $15
Mallory fuel filter #3140 used $30
SBC chrome valve cover "Chevrolet" used $30
Auto Meter oil pressure warning light $20
GM A body rear coil springs and air bags $50
CO2 bottle clamp blue $20
Manley triple valve springs. 275-300lbs @2.000 $75
Mark Williams lightened spool with bearings 35 spline. $200
GM 12 rear end cover $10
Following parts are new....
Moroso 63760 thermo switch for water pump or fan $25
Child's and Albert oil rings .060 over 283 (3.935) 3/16 $50
2 pairs Mr Gasket 5800 head gaskets 400 SBC $25/pr
Felpro BBC 1410 header gaskets $10
King BBC CR849HP -.030 Rod Bearing Set $50
Federal Mogul SBC -.020 main bearings large journal $40
PSI DR1247ML valve springs $200
I can send pics of items if you're interested.
Thanks for looking!
Call or text 253-906-9643
Mark Faul is offline   Reply With Quote
