Old 01-12-2016, 01:19 PM   #1
hardtimes
Default Questions about gear ratio
I have a bracket car with a mild 408w shift at 6000.
Car has 4.33 gear and 28" slicks only crossing the 1/8th @5900 was thinking about putting more gear in it.
Looking at 4.56 or maybe 4.71. How much ET do you think this will pick up and which gear should I go to.
Also someone told me with more gear that the car would be more consistent (less effected by weather changes) is this true??
hardtimes is offline   Reply With Quote
Old 01-12-2016, 09:52 PM   #2
Jeff Blanchard
Default Re: Questions about gear ratio
There are some good calculators available online to help when considering things like gear changes. One of them is Wallace Racing Calculators.com
Jeff Blanchard
353C / Stock
Jeff Blanchard is offline   Reply With Quote
Old 01-13-2016, 06:39 PM   #3
GTX JOHN
Liked 2,493 Times in 700 Posts
If you have a effective converter that is sized correctly.......
I think the difference between the 1/8mile times with those
gear spreads would be well under a tenth.
The 1/8 mile times on my small block stockers going from
4.56 to 5.13 at sea level were well less than a tenth.
I am pushing 70 and sometimes start in 2nd gear now and then.....
the difference in 1/8 mile is under 2 tenths.
It is sure nerve wracking go thru the lights at 7700 instead
of 6900 in 1/4 miles.
John Irving
741 Stock
741 Super Stock
