Old 01-12-2016, 12:26 PM   #1
sst1226
sst1226's Avatar
Liked 11 Times in 2 Posts
Default 400 Pontiac
Engine is complete from pan to intake(no carb) and has been disassembled for freshen up.
Factory Nodular Iron Cast crank (1967-1970 400)casting #9795480 cut .010 under,
Factory Cast Iron Rods cut .010 under,
TRW pistons .030 part # L2262
Nunzi Hydraulic flat tappet cam, Crane Lifters also have a Crane Ram Air T cam new,
Harland Sharp roller rockers,
Moroso 8qt. pan, Melling High volume oil pump,
factory HEI
1968 #16 heads fully ported 72CC, chamber.
Edelbrock Performer RPM intake, also comes with two Torker I intakes, one small port and one port matched to heads,
Numbered balancer,
Hooker long tube comp headers for 2nd gen Firebird chassis.
Short block and heads will need basic check and freshen up at machine shop.
Comes with rolling engine cradle, alternator & power steering brackets, stock starter, tall and short valve covers and extra stock balancer and flywheels.
Combo ran 12.70's @ 103mph in a 3900lb. street car.
Mario DiTeodoro III SST/SG1226 STK126M
sst1226 is offline   Reply With Quote
