Old 01-11-2016, 08:27 PM   #1
JeffM
Liked 5 Times in 5 Posts
Default Garage Sale Computech, Biondo, Turbo Action, MSD
Canton Racing accusump mounting brackets new in original packaging 24-200 - $10.00
CSR SBC/BBC anodized red thermostat housing (912R) with spare o rings $65.00 - Used
ARC 3100 switch panel –$100.00 - used
Autometer electrical 100psi sending unit with 3ft of -3 braided line – $30 Used
MSD 3 Launch control with 3 step PN 8735 – Used $135.00
Biondo Racing Terminator trans brake button - No shims included– Used $90.00
Computech Datamaxx data acquisition main module with harness. $450.00 used
Computech Datamaxx LCD screen $500.00 used
Computech clamp on EGT kit with module $150 used
Moroso 5x7 heading pad PN 23996 $45 new
Turbo Action Cheetah SCS 3 speed shifter kit with Biondo cheetah reverse 3 speed C02 solenoid with cable and detent bracket and wiring $375.00
MSD 7 AL2 with trigger wiring $350.00 used
Rossler Turbo 400 transmission with Ross lock trans brake. Reverse Pattern. 2.48 first gear with steel drum. Deep aluminum cast pan. Lokar aluminum quick coupler for dipstick. Dipstick not included. Recently freshend by Defiance Transmission (Ken Shawver) and ready to run down the track. $1550.00
Powerglide transmission with stock case, ATI 1.98 S/S with coan 300m PG input. Stefs pan with heater, TCI brake, freshened by Defiance Transmission (Ken Shawver). Less than 20 passes on the new 1.98 gearset. $1350.00
7" PG converter - 6200 stall behind 327/275hp combo - $600.00
Simpson jacket large black sfi 3-2A/5 $125
Simpson pants large black sfi 3-2A/5 $125
New in 2009
pictures available upon request
superstock@live.com
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
