Old 01-06-2016, 12:13 AM   #1
Todd Tuohey
Default Stock Eliminator 440-6pk motor and Jerico DR-4
For Sale:
Complete, carbs to pan 440-6pk engine with very few laps on it.Was in 1970 Cuda ( B/S & C/S) All new parts, quality pieces. 906 heads,Smith lifters,Crane springs, Hughes rockers, Manley valves, Diamond NHRA pistons, K1 rods, carbs done by Little, original intake manifold, I/J Teflon crank scraper, Hemi pan. Can hear run if schedules work out, still in car, but pulling it soon. $5,000
Jerico DR-4 tranny. Same car as above. New McLeod soft lok clutch, set up by Tim Hyatt. Hayes disc. Older tranny, but only has 75-100 runs on it. Clutch and pressure plate maybe 15 runs.Have all original specs from when it was ordered new. I believe its a long shifter.
All parts located near Syracuse NY. Willing to help with delivery within a reasonable distance.
**** DEPOSIT TAKEN ***** IF DEAL DIDNT GO THRU, I'LL RE-LIST AS STILL AVAILABLE ************** Thank You
Todd Tuohey is offline   Reply With Quote
Old 01-06-2016, 08:49 AM   #2
T-Bolt Racer
Default Jerico DR-4
Top and bottom loader mag case wide gear what are the ratio's?
T-Bolt Racer is offline   Reply With Quote
Old 02-27-2016, 12:22 AM   #3
Coleydog
Liked 53 Times in 38 Posts
Default Re: Stock Eliminator 440-6pk motor and Jerico DR-4
Engine still available?
