Old 07-08-2007, 06:21 PM   #1
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default 400 Pontiac Block, Crank, Timing Cover
I have listed the following items on E-Bay:
Standard bore 400 Pontiac engine block. Cleaned, new cam bearings.
Block #500567 Date Code B287
Item #220129232771
http://cm.ebay.com/cm/ck/1065-29296-...9232771&lk=URL
Timing cover is for 64-68 V8, with 8-hole flange for water pump
Item #220129244846
Crank is iron 389 crank, with adapter ring for 400 flywheel
Item #220129235213
Will consider adding a "Buy It Now Price" if a real racer has an immediate need.
Call Tony- 610-431-7740
or acurcio910@aol.com
Tony Curcio is offline   Reply With Quote
