Old 12-31-2015, 09:56 AM   #1
Lonnie Grim
Default LS Pistons for 4.125 bore New
Full set of custom Ross pistons, pins, and Total seal ring package. Everything is brand new. I had ordered these and then discovered that the LS7 block would need to be bored to larger size. Listed below is the piston info. I have all of the paperwork if you do not see any of the info you are looking for. My mistake is your gain. The complete package was $ 1438.46 at my door. I will take $1100 and pay UPS ground freight within the US.
lonniegrim@aol.com
4.125 Bore, .927 pin, comp height 1.182, ring groves are .0485, .0485, .0795,
ring lands are .185, .145, .090, pin length 2.300, dome height .110, int v.p. depth .160, exh v.p. depth .150, Piston weight 476 grams.
Total Seal complete ring package.
Lonnie Grim is offline   Reply With Quote
