Old 12-10-2015, 11:56 PM   #1
Dennis.Lund.Jr
Liked 3 Times in 1 Post
Default Garage Sale
-MSD Digital 7 Ignition, 7530T - $350
-New in package - K&N X-stream, cone filter system for dragster hood scoop, dominator - $125
-APD 1150 Dominator, alcohol, bolted down once, approx. 50 runs - $750
-FSR Aluminum radiator - 12 AN o-ring fittings, carbon shroud, accepts 6.5" fan, 13.5" x 10" x 2" - rubber grommet mounting pattern (7.25" x 9.5") - $250
-BTE short Powerglide billet rear cover, roller bearing - $50
-Strange 5/8" 4" wheel studs, steel - $40
-7" A-1 converter BC 350-44, Mechanical Diode Sprag, PG input, 35 degree fin, #4 stator (13 blade),4 for additional 2-300 rpm over base stall Full hard hit (44), Stalled 7500 behind 850 hp sbc in a dragster. -$600
- 9" Hughes converter GM96+1/4 019SC+1, out of 6.40 N/A top dragster with 632 - $800
- SB2 headers, 2.125" primary tubes. 4 O2 bungs, no collectors. - $250
If you want to make me offers, I'll listen.
Dennis
563-370-5110
Dennis.lund.jr@gmail.com
Thanks,
Dennis
Dennis.Lund.Jr is offline   Reply With Quote
