Old 12-05-2015, 10:05 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Accel DFI Gen 7 System & 77062 Wideband o2 w/ Data Recorder
$1200 obo. Call or text 610-996-8784 or email bobby.fazio@gmail.com
What is included:
-Accel DFI Gen 7 ECU that was flashed to the latest Software back in 2012. I don't believe there have been any updates since.
-Main Wiring harness for any vehicle - there are GM style connectors on these harnesses but if you have a different make then you will have to purchase adapters such as with Ford.
-Accel DFI 77062 Wideband o2 data recorder box. Records air/fuel ratio, RPM, wheel speed, injector duty cycle, pulse width, manifold pressure, coolant and air temps, ignition voltage, knock sensor, TPS, etc. very useful for racing!
-DFI Calmap 25' Serial to USB converter box for laptop hookup
What you will need to get:
-Bosch 17014 wideband o2 sensor from many parts warehouse.
-GM style MAP sensor - $40 from JEGS
-GM style Air temp sensor and coolant temp sensor for manifold - $13.99 each from JEGS
-Idle air control motor if wanting to use one. Ford requires an adapter.
-Throttle position sensor for your application.
-Dual Sync Distributor if wanting to run in Sequential fire. I am selling the Small Block Ford 77201 with spare large and small cap and rotors. Will sell mine for $250
-Fuel Injector Harness for your application - I am selling the Ford 5.0 separately. These are $140 from JEGS. Will sell mine for $75.
'65 Mustang SS/L & L/SA
Bobby Fazio is online now   Reply With Quote
