Old 11-18-2015, 08:43 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default bbc clearances
My buddy's engine is coming up a little tighter than I've been.
Drag only 427+.030 bbc with GM 1077 aluminum heads, steel rods, older Manley 12.5 pistons turning 7300 tops.
Piston is out .003 and he wants to use a .039 compressed gasket. Piston to wall clearance is .005 -.007, is this quench too tight?
He has loads of piston to valve clearance except radially. He used clay and has .030-.040 at the center of the piston, where the little triangle is. Too tight?
Thanks for any help
Ron Gusack is offline   Reply With Quote
