Old 11-01-2015, 04:15 PM   #1
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Default 2002 Pontiac Firebird O/SA - Certified Cage
10 Point Cage
Will certify to 8.50
Tied into through floor subframe connectors.
Simspon Camlock Seatbelts (Good thru 2015)
Custom Built Torque Arm. (Slip joint front mount)
Boxed control arms w/ Poly Bushings
BMR Anti-Roll
Wilwood Master Cylinder w/ Firewall Brace
Wilwood Rear Brakes
Holley HP EFI
Custom Engine Harness
Holley Coil Pack Ignition
231 V6 Engine
Metric 200 Trans
2.75 Low Gear
2 Torque Converters (ATI & Turbo Action)
B&M Quarter Stick
Moser 12 Bolt w/ Girdle Cover
33 Spline Axles, 5/8 Wheel Studs
Aluminum Spool
5.13 Gear
Steel driveshaft w/1350 Joints
Auto Meter Gauges & Tach
Fuel cell in trunk
Lots of 3800 parts available
2 extra full sets of wheels available
Extra sets of front runners available
Extra rear tires available
Custom built flip down tree blinders.
Single owner car with original paint and comes with title.
Have been 12.28 heavy for O/SA at zMax in the Spring. Runs 12.60s in bracket trim.
When we re-built the car with the cage we had in mind to run B/SA with an LS1 or have a fast footbrake car. Build a set of motor mounts and buy a Holley Engine Harness to drop in an LS1 easily!
Car is clean and well built. Still has rear seat even with full cage. Works very well. Have been 1.58 60’ at O/SA weight. Swap to an adjustable front strut and global west front bushings and you have a top notch stocker!
More pictures upon request.
Less Engine/Trans/EFI Harness $13,000
Turn Key w/ Extras $18,500
May consider trades for backhalf S10 or Vega.
Text/Call: 540-454-0115
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
