Old 10-25-2015, 12:15 PM   #1
dean ribeiro
Liked 238 Times in 78 Posts
Default 1985 Pontiac Firebird SS/GTGA-IA -1.20+ UNDER
1985 PONTIAC FIREBIRD GTIA, GTHA, OR GTGA
Car was just #1 Qualifier and Runner Up at the 2015 PA Dutch Classic @ Maplegrove Raceway
RUNS 1.20+ SECS UNDER INDEX
ENGINE: 1973 PONTIAC 400CID, 200/275 HP, 4X HEADS,
COMP CAMS CAM, CROWER LIFTERS, CP PISTONS, TOTAL
SEAL RINGS, OHIO CRANK, EAGLE RODS, JESSEL ROCKERS,
BOP BELT DRIVE, MSD DIST., CUSTOM CARB, INTAKE,
HEADS & HEADERS; TITAN OIL PUMP & CUSTOM STEF’S
OIL PAN
DRIVE TRAIN:
ATI CONVERTER, SELECT TH400 (ALUM., BRAKE, ETC)
ALUMINUM DRIVESHAFT, MOSHER 12 BOLT & AXLES
CHASSIS: C.M. CAGE, 2 X 3 CHASSIS, C.M. 4 LINK, QA1 REAR SHOCKS,
KONI FRONT SHOCKS, WILWOOD DISC BRAKES, ACCUSUMP
LINCOLN AIR SHIFTER, Autometer on board computer w/ EGTs & Accelorometer
3000 LBS MIN CAR WEIGHT WITH EXISTING SET UP
SPARES: SLICKS & WHEELS, FRONT TIRE & WHEEL, SELECT TRANS,
ATI CONVERTER, FUEL PUMP & REG, MSD-7AL2, VALVE
TRAIN PARTS (SPRINGS, LIFTERS, ROCKERS), ATI DAMPER
& TRIGGER WHEEL, IGNITION PARTS, DRIVE SHAFT, BRAKE
PARTS, CO2 BOTTLE, PLUS A LOT MORE!
This car has been scienced out for over 28 years! It is very trick and has been engineered for consistency and performance! Purchase and go immediately towards the top of the qualifying list. All fabrication & log books will be included with purchase of car.
Please see racing Junk Ad #182579203 for Detailed Pics
Pricing: $38,000 W/SPARES, $35,000 W/O SPARES Engine will be completely Fresh (0 runs)
Call Dean Ribeiro @ 603-785-7866 cell Serious Buyers only please
NOT interested in any trades.
Last edited by dean ribeiro; 11-01-2015 at 12:02 PM. Reason: Engine being freshened
dean ribeiro is offline   Reply With Quote
