Old 09-29-2015, 02:13 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1966-1969 396 & 427 Warranty Motors & Parts
1969 396-350HP warranty exchange engine rebuilt standard bore and complete from the intake to the pan. 3955272 block dated J-5-8 with 6223 steel crankshaft, 3931063 heads and 3931067 intake all dated in February of 1969. $3500
1969 427 4 bolt warranty exchange motor standard bore with casting number 3963512 dated L-9-8. Motor is standard bore with original 7/16 dimple rods, 6223 steel crankshaft, 3919840 square port heads with crane roller rockers both dated in January of 1969. Motor was rebuilt and run and is very clean on the inside $4500.
1969 3919840 square port heads both dated A-21-9 off of a super stock set up $1750
1968 396 4 bolt block dated in December of 1967 #3916323 clean 30 over ready to build. It has new freeze plugs and was cleaned and magged $1750.
1966 3873858 heads redone dated I-30-5 & J-4-5 $2500.
3/8 dimple rods $350
BBC deep oil pan $50
Accell dual point distributor and coil B.O.
Holley carb #4780 800 CFM double pumper $175
Can ship parts if you cannot pick up. Can send pictures with an email address. Can be reached for any questions at 330-770-2517.
dlv4540 is offline   Reply With Quote
