Old 09-23-2015, 10:02 PM   #1
66ss
Default 62-67 nova TRZ rack and pinion kit and tubular lower A arms
Up for sale is a TRZ Motorsports 62-67 nova rack and pinion kit. Kit has been mounted in my car and has 0 time on it. Lower control arms are mint. New rod ends just installed. Steering shaft made up and ready to go. Will work with any fenderwell headers. Will need to make/purchase the lower A arm mounts because I did weld them into my car. They are the only thing that needs to be welded. The rack crossmember bolts in
Comes with everything you need to swap your nova over to rack and pinion
Steering. The lower arms are way more sturdy then stock
Rack kit is $900
Lower arms are $400
$875
(516) 410 9372
66ss is offline   Reply With Quote
