Old 09-19-2015, 04:48 PM   #1
FrankM
FrankM's Avatar
Liked 3 Times in 2 Posts
Default 91 Camaro
All steel except fiberglass hood (Harwood bolt on).
Runs 10.8 in the 1/4 and 6.8 in the 1/8.
350 +.070 SBC with Chevy iron heads (heads are ex-super stock) milled to 58cc, Eagle crank, Venolia pistons, Comp Cams full roller, Crower roller rockers, Ed Quay front and mid plate. BG400 fuel system, brand new QFT 850-AN carb.
ATI Powerglide, 1.98 straight cut gears, ATI converter, ATI transbrake. Dynotech aluminum drive shaft, Moser gun drilled 5 star flange axles, GM 12 bolt with 5.14 gear
Weld Alumastar wheels all around, Wilwood disk brakes
MSD Digital 6, Biondo mega85, Hurst quarter stick with electric shifter.
Car comes with complete interior (except carpet). Currently only dash, console and door panels are in the car. Also have factory steel hood.
$12500 turnkey or $7500 rolling
614-546-8480
FrankM is offline   Reply With Quote
Old 09-24-2015, 09:09 PM   #2
RACER1530
RACER1530's Avatar
Send a message via AIM to RACER1530
Default Re: 91 Camaro
How big tire will it take ?
Any cage?
Fordyce Motorsports
SC 1538 / SC 153R
RACER1530 is offline   Reply With Quote
Old 09-26-2015, 08:58 PM   #3
FrankM
FrankM's Avatar
I originally had 33x10.5W and now have 31.25x12.2.
It has an 8 point roll bar with a ladder bar setup with coil over shocks in the rear. It is a factory frame with frame connectors, it is tubbed.
