Old 09-11-2015, 08:25 PM   #1
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default EZ GO belt question (gas burner)
got a question on drive belt tension, adjustment on a
E Z go 86M12 .
won't hardly pull itself and appears really loose
haven't found a manual for it yet but I just acquired it this morning..
Old 09-11-2015, 08:38 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: EZ GO belt question (gas burner)
no they just get tight when the cvt clutches engage. if the belt is worn too much it gets narrow and will slip a lot. jack the back up and start the eng. rev it , and if it looks like the drive clutch on the engine tries to engage (get narrower on the belt) but it still wont drive the rear driven clutch , your belt is to worn. there is a spec on width of the belt. but I don't know the dim.. hope this helps.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 09-12-2015, 08:09 PM   #3
Tom keedle
Tom keedle's Avatar
thanks mark, I DID find a spec and it's 1 3/16" wide, mine is .996....supposedly it eats belts but the pulleys look good....abuse?
anyway, got a new one ordered and i'll give it a shot....sure isn't hard to change
