Old 09-07-2015, 06:53 PM   #1
rod
Liked 20 Times in 15 Posts
Default rim width/effect on tire?
I have F/X 28.5 x 9 tires for my Nomad. I started with 7 inch rims, because that is what I had. I see most guys are using a 10 inch rim.
8 & 10 are the two most common widths and availability.
what effect does the rim width have on the tire [center section, tread width and height-both setting and at speed]? std. trans, 105 at the line
given a choice, what is best?
thanks, Rod in AZ
rod is offline   Reply With Quote
