Old 08-16-2015, 05:29 PM   #1
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default 71 454 LS5 Stocker Motor Fresh and Cheap!
71 454 365@355/365 depending on car, true 71 ls5 2 bolt block, gm cast crank indexed and ground +.013, eagle H Beams, venolia 454-270 flat tops .040", 820 Heads with stainless valves, bronze guides and comp springs, 287 intake, Comp pro magnum rockers, guide plates, push rods, lifters, and timing set, Lunati Camshaft. Engine made 464HP @5400 and 510ft lb at A&J with 6 qts of 15w40 in the pan. Currently has a kick out oil pan and crank trigger ignition for use in stock gt. $4500 CDN intake to pan with ignition or $4000 CDN without, That's roughly $3000 USD right now, a steal! We are in Nova Scotia Canada and can help with shipping arrangements. Call Chris @ 902-956-1962
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
