Old 07-23-2015, 10:59 PM   #1
JeffM
Liked 5 Times in 5 Posts
Default Superstock transmissions and Aeromotive fuel system parts
Rossler Turbo 400 transmission with Ross lock trans brake. Reverse Pattern. 2.48 first gear with steel drum. Deep aluminum cast pan. Lokar aluminum quick coupler for dipstick. Dipstick not included. Recently freshend by Defiance Transmission (Ken Shawver) and ready to run down the track. $1750.00
Powerglide transmission with stock case, ATI 1.98 S/S with coan 300m PG input. Stefs pan with heater, TCI brake, recently freshened by Defiance Transmission (Ken Shawver). Less than 20 passes on the new 1.98 gearset. $1350.00
7" PG converter - 6200 stall behind 327/275hp combo - $600.00
Hurst Roll control new in box 174-5000 - SOLD
Aeromotive external fuel pump 11106 - new in box $300.00
Aeromotive in line fuel filter – 10 micron New – $75.00
Aeromotive in line fuel filter – 100 micron New- $75.00
Aeromotive in line check valve – 8 and and out New - $50.00
Aeromotive fuel filter mounting bracket 2 bolt New - $50
Aeromotive fuel filter mounting bracket 1 bolt New - $50
Call, PM, or text if you have any questions
260-223-0157
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
