Old 07-23-2015, 01:49 PM   #1
Charles Hawthorne
Smile 283/220 HP Stocker Motor For Sale
This is a fresh, new motor! Unfortunately I can't afford to both class race and go through another round of medical tests and procedures for cancer at MDAnderson -- so I have decided to part with the motor.
Wade Owens Prepared Motor:
283 Block .062
Bullett Steel Crank Indexed at .013
Manley Rods - Bushed
B&B Piston Pins
Ross Coated Pistons .062
Bullett Cam Shaft 4/7 swap
Cliff Sherman Lifters
Larry Stewart Oil Pump
Oil, Pan, Windage Screen
Timing Cover Set
Cometric Head Gaskets
Aluminum Harmonic Balancer
Total Seal Rings
Tilton Starter
CSR Electric Water Pump
MSD Distributor with Plug Wires
Deano 4GC Carburetor
Transmission Converter
Biondo Aluminum Valve Covers
520 Heads, 459 Manifold Prepared by BES Racing Engines
Pac Springs, Retainers and Keepers
Spare Parts:
1- 283 Standard Block
1- 283 Standard Cast Crank
1- Set of Stock 896 Heads
1- 3866922 Manifold
1- 3844459 Manifold
1- 3844457 Manifold
2- 4GC Carburetors (cores)
1 Set of Stock 461 Heads
1- 3905393 Intake with 7023212 Quadrijet Carb
1- 3875954 Intake with 7041211 Quadrijet Carb
1- 3872783 Intake with Holley Carburetor 3875964-DB (list no. 3230 087)
1- New Comp Cams 283 camshaft CS5688/5652 H108
TOTAL PRICE: $11,000
Please Contact: Charles Hawthorne
chas4000@hotmail.com
281-770-3684 (cell)
Charles Hawthorne is offline   Reply With Quote
