Old 07-23-2015, 07:44 AM   #1
Dougherty20
Default 69 Camaro NDRL Nostalgia Class Champion
2012 Nostalgia Drag Racing League Nostalgia Gas Class Champion.
Car is a complete roller. Strong 522 BBC engine. Made 940 HP and 860 foot pounds of torque. Naturally aspirated. Short block and heads have less than 60 passes since new. Car runs 8.60 at 155 MPH. Ladder bar car, front halved and back halved. Chassis cert to 8.50 in April 2015. Funny Car cage. Lemons Ceramic Coated Headers custom built for car, cost 1800 new. Coan 5500 stall converter Coan Pro Brake Coan built Powerglide Fiberglass front fenders, hood, trunk, and rear quarters. Car weighs 2600 lbs less driver Billet Specialties Street Lite Wheels, 5/8 studs.
Full Lexan Windows
DJ Chute
Full fiberglass front end
T&D Shaft Rockers
Brodix -3Xtra 351CC heads by Jones Engineering
Titanium Valves
2-950 Methanol Carbs by Pro Systems/Patrick James
Dart Tunnel Ram ported by Jones Engineering
JE Pistons, 14 to 1 compression
Manley Rods
Callies Crank
Isky EZ Roll Red Zone Lifters
Comp Cams Cam
Dart 9.8 Block with oversized bronze bushing lifter bores
Moroso Aluminum Pan
Moroso Vacuum Pump
CSR Water Pump
Aeromotive A2000 Fuel Pump and Billet Fuel Filter
Aeromotive Bypass Regulator and Fuel Log
Moroso Valve Covers
MSD Crank Trigger
MSD Digital 7 Ignition
MSD HVC 2 Coil
MSD Digital Tach
MSD Distributor
Dedenbear Electric Shift
Wiling to consider selling engine and roller separately
$24,500
Dougherty20 is offline   Reply With Quote
