Liked 116 Times in 20 Posts
I'm selling my PMR (Phil Mandella) built Super Stocker. It is set up for a wedge but a Hemi will bolt right in. I have 2 sets (tall and short deck) of Performance Welding stainless header. The car has all the best stuff including Racepak (dash, 2-O's, 8 egt's, water temp, oil pressure and temp, carb pressure, pump pressure), Lamb brakes, Lamb front shocks, Penske rear shocks, Precision shifter, return fuel system. The car works great. Just went 1.21 60' @ Fontana and was the #1 qualifier. $70,000 as a roller. Also can be bought complete.
I also have an Erik Jones built steel stage V headed low deck 440 6 Pack Super Stock motor. Small bearing crank, Carillo rods, Jesel lifters and belt drive, Hogan manifold, roller cam bearings. T & D rockers, Johnson oil pump. All the best parts. It has been 9.19 in my Challenger @ "E" weight. $19,000 I have the SS/AH Hemi that came out of the 68 Cuda I just bought. Fresh...only a few runs on it. 900hp. Barton Rockers, Jesel key way lifers and belt drive, tunnel Ram. It just went 8.99 @ Fontana set really soft. It's probably an 8.80 motor. $22,500. Thanks, Eric 480-326-5399 Last edited by Eric Bell; 06-11-2015 at 09:03 PM. |
