Old 05-11-2015, 12:00 PM   #1
ZenzenRacing
Liked 53 Times in 17 Posts
Cool Alum vs Steel Drum
Need your help! Do you think there is alot of Et or MPH change with a steel or alum drum(5 Clutch pack) in a 2 speed? SS/ 275hp 327chev. We killed a new Ati alum in one pass! Thanks, Ron
ZenzenRacing is offline   Reply With Quote
Old 05-11-2015, 12:33 PM   #2
Default Re: Alum vs Steel Drum
An aluminum high gear drum makes a measurable difference in a Powerglide, especially in a small block car. If you hurt a new ATI part, call them, they'll make it right if it is their fault.
Old 05-11-2015, 12:42 PM   #3
ZenzenRacing
Thanks Alan, I will call them and see what they say. Just haven't had luck with warr parts. It was the new one with the steel insert. May have to put the old Ati back in for the next race.
Old 05-11-2015, 02:32 PM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,940 Times in 584 Posts
I found no difference when I went from the aluminum drum to the steel drum. I used the Coan lightened steel drum in one trans. That worked real good. I have a stock one in the trans I have I the car now. What happened to the drum that just tore up?
Mike Pearson 2485 SS
Old 05-11-2015, 03:44 PM   #5
ZenzenRacing
It was torn up bad, like the band wasn't releasing in high. All we did is replace it with a new band and steel drum and cleaned the trans and it was great. ATI won't call back after a few messages left.
Old 05-11-2015, 04:16 PM   #6
What band did you use with the aluminum drum? What was the band adjustment procedure?
Old 05-11-2015, 04:31 PM   #7
ZenzenRacing
My trans guy did that but I thought it was 3 and 3/4 out, and the red band.
Old 05-11-2015, 04:37 PM   #8
Mike Pearson
I always used a red band and ran the band at 3 1/2 turns from snug. I had some problems with a front pump that was not giving me enough pressure and was eating bands and drums. You need at least 170 lbs of pressure according to Coan. I use a Kevlar band on the steel drums. I would only use an aluminum drum if you are trying to get that last .001 or .002 to set a record or a class run situation. The steel drum does not leave the gray mess in the pan either. The lightened steel drum from Coan is a good alternative.
Old 05-11-2015, 04:44 PM   #9
ZenzenRacing
Any idea how much? Does he keep them on hand?
Old 05-11-2015, 05:12 PM   #10
Tracy Robbins
Liked 25 Times in 11 Posts
I have used both and the aluminum drums don't hold up especially in higher rpm applications. On the other hand the lightweight steel drum from Coan worked great...the problem is they no longer make it. I called 2 weeks ago because I couldn't find it on their website anymore and was told they couldn't get enough steel drums to make them but if you have 10 drums you could send them in and they might would machine them. So there is an option to get them made.
Tracy Robbins
SS 9766
Tracy Robbins is offline   Reply With Quote
