Old 05-05-2015, 04:56 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default notes about SBC 327 crankshaft, or if I had it to do over
Racers, after spending time with the Super 10 engine research I decided to build a 300/327 engine combo. I think that decision is good and fits well with the Super -10 GT super stock class.
I decided on a Dart SHP Pro block, again, I think a good decision.
About the crankshaft, after considerable searching I found a suitable 327 factory shaft then sent it to Mile High for full work over. Again, very happy with the work and pricing from Mile High.
The problem, main bearings. A few years ago a special thick bearing was on the market that adapted a 327 main to a 350 main [the Dart block is of course 350 main] The thick bearing can no longer be found.
After more searching I did find spacer bearings but I did not like the fit. So, align hone the spacer bearings in the block to get the bore true.
It is assembled with those honed to fit spacers and all is OK.
Knowing what I know now, a new shaft with 350 mains and 327 small pins would have been a better choice and given more bearing selection options.
So, maybe my experience might help another race who is considering a 327 build.
Larry Woodfin 471W
Old 05-05-2015, 05:08 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: notes about SBC 327 crankshaft, or if I had it to do ove
A large journal 327 crank is lighter than a small journal crank.
Old 05-05-2015, 06:07 PM   #3
Bill Moulding
Well that is interesting Dwight. How much weight are we talking about?
Bill Moulding is offline   Reply With Quote
Old 05-05-2015, 08:46 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Both Jegs and Summit , among others, sell Clevite MS1110H Thick bearings, There is also MS1110H-1 available. Hope that helps for the future.
ss3011 is online now   Reply With Quote
Old 05-05-2015, 11:40 PM   #5
Dragsinger
ss3011,
the spacer bearings are listed in a number of location on the web but when you call "those are no longer available" is the answer. Even though the web site says, "will ship from manufacture" Clevite no longer produces them nor King nor any other manufacture that I could find.
Larry Woodfin 471W
Old 05-06-2015, 02:51 AM   #6
ss3011
ss3011's Avatar
Just got off the phone with Summit, they verified they have 4 sets of those bearings in stock ready for shipment.
Old 05-06-2015, 04:48 AM   #7
Dragsinger
I forgot to explain, the mains are .010" under , that is the problem with finding the thick bearings.
Larry Woodfin 471W
Old 05-06-2015, 08:09 AM   #8
Dwight Southerland
I don't remember exactly. A couple of pounds, I think.
Old 05-06-2015, 11:26 PM   #9
Jim Hawkins
Liked 115 Times in 35 Posts
I used a large journal crank in my 327 and the rods are turned down to small journal. I checked before and was surprised how much lighter the large journal cranks are.
Jim Hawkins is offline   Reply With Quote
