Old 05-05-2015, 01:20 AM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Racepak Sportsman question
On the racepak sportsman the yellow wire that is a part of the driveline sensor it says connect to 12v event. Does that go to a 12v source all the time or a 12v source that is switch activated or something else. The instructions doesn't show where it goes. Thanks. Ed
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 05-05-2015, 07:37 AM   #2
Jeremy K
Default Re: Racepak Sportsman question
The "12 Volt Event" wire would go to something that has 12 volts applied or taken away that you are interested in seeing during the run. In your Datalink software, it will read 0 when there's no voltage, and read 1 when activated.
Jeremy K is offline   Reply With Quote
